1 - 10 of 10 Posts
Indian FTR coolant change for extreme triple digit South TX Temps – I Switched to Evans Waterless Coolant – a hand held Mighty Vac came in very handy for the radiator – follow your Tech Manual (2.5 qts is plenty even for the reservoir- and Evans Flush) – without water, it builds no pressure in the system at extreme temps and runs cooler (when your kick stand starts sinking into the asphalt – when doing 80 and feels like a wall of fire……..it’s warm out there- lol) Tech manual link https://www.service-shop-repair-manual.com/2019-indian-ftr-1200-1200s-part-9929391-r01-service-shop-repair-manual/
Still running the Evans...? How's it working for you
I've checked it severals times, to see if it needed topping off (NO) not even the reservoir - no corrosion either - see Jay Leno's garage - it's for the life of the vehicle - it'll never build pressure in the cooling system, hoses and pump will last longer
Oh- one more thing..... when water based coolants start to break down, they become more conductive and electroplating occurs at 1 VDC + due to eddy currents in the block (Gunk from different metals) - if you bore scope an engine block you'll see. Evans doesn't do that - I'm not sure if they used a a silicone type based fluid? Your engine will have to be glowing cherry red and on fire, for the evans to boil over
Hey fella, thanks for all the info on the Evans. Question for ya... I took my radiator cap off a couple of weeks ago.. Is the cap like a normal radiator cap or is it longer with a long spring. I was in a rush putting it back on as the coolant from the overflow was pouring out.... But in my panic I swear it had a longer spring. Thanks in advance fella 👍
Yeah- the first time I backed off the set screw on the cap for removal – it did over flow, and the engine was cold – luckily I had a rag around the base, in case it did that – my Triumph Commander did the same thing at first – it ran on Evans just fine after – I would guess there was a pressure bubble in the system – can you imagine the pressure when it’s at temp, the cap spring has a pressure rating (PSI) to vent to reservoir (the spring is average I guess) – when coolant pressure (PSI) pushes the spring open and allows excess pressure to the overflow or reservoir tank
611940
611941
basically over pressure is vented from a hot system - as it cools vacuum draws it back into the system from the reservoir - sometimes you may get a bubble in the system- overflows when you remove the cap - Water makes steam and build pressure -that's not gonna happen with waterless coolant
If your in England - don't worry about overheating, do worry about internal corrosion
- I'm in Southern Texas - I worry about both...............
Oh - and rubber hoses, expand under hi temps and pressure - as they cool - they squeeze the coolant - so don't worry about it overflowing - next time use a rag around the base............
1 - 10 of 10 Posts
