1 - 1 of 1 Posts
G
$31.999
Features
Styling
Chromed tear drop Halogen Headlamp
Auxilliary driving lamps
Die cast console - color matched
Black and polished engine with chrome covers
Chromed spoke wheels
Available billet wheels
Two into one stainless steel exhaust system with three way catalytic converter and chromed shields
Available long skirt fenders and dual tone paint
Polished brake calipers
Powertrain
Air cooled, pushrod, Power Plus 105ci engine
Closed loop, sequential, port injection with heated oxygen sensors
Six speed transmission
Chassis
Seat: Two person seat available in black, tan and red leather, with or without fringe
5.5 gallon fuel tank
Brembo brake system with dual floating rotors and 4 piston calipers in the front and single floating rotor and two piston caliper in the rear.
Two accessory 12 V outlets
Electrical
Tank mounted analog speedometer and multi function digital display
Charging system 42 Amps
Lamps: Tear drop head lamp, glass front fender light, auxilliary spot lights
There are no electrical relays in the system
Note: All specificatons subject to change
Specifications
Note: All specifications subject to change
Dimensions
Length 100.5”
Width 40.5”
Height 50.5”
Seat Height Laden 26.69”
Seat Height Unladen 27.89”
Wheelbase 68.4”
Dry Weight
(will vary for each model) 746 lbs
Running Order Weight 773 lbs
Rake Steering Head/Trail 34°/5.92”
GVW - Gross Vehicle Weight 1260 lbs
engine
Engine Type Power Plus 105, Air-Cooled
Displacement 105 Cubic Inches
Bore x Stroke 3.966 x 4.25
Compression Ratio 9 to 1
Engine Torque 100 ft*lbs (TBD)
Fuel System Closed Loop Sequential Port Fuel Injection
drivetrain
Primary Drive Chain
Gearbox Six Speed
Gear Ratio (overall)
1st 10.441:1
2nd 7.090:1
3rd 5.172:1
4th 3.984:1
5th 3.193:1
6th 2.771:1
Final Drive Belt
Chassis
Frame High tensile steel, monoshock
Suspension/Front Diameter 41 mm/Travel 108 mm
Suspension/Rear Single shock/travel 73 mm
Brakes/Front Dual Caliper with Floating Rotors 11.5” Diameter
Brakes/Rear Single Caliper Floating Rotor 11.5” Diameter
Tires/Front 130/90-16 Black or White Wall
Tires/Rear 150/90-16 Black or White Wall
Wheels Wire spoked
Exhaust System Two Into One Stainless Steel With Chromed Shields
Electrical Instruments Tank mounted analog speedometer and muti function digital display
Charging System 42 Amps
Lamps Tear drop head lamp, glass front fender light, auxillary spot lights.
Warranty
2 Years
Pricing
$31,999*
Standard colors
Thunder Black with Silver Script
Thunder Black with Silver Head Dress
Available colors
$199 Indian Red with Gold Script
$199 Indian Red with Gold Head Dress
$899 Thunder Black & Winter White w/ Silver Head Dress
$899 Midnight Blue Metallic & Winter White w/ Silver Head Dress
$899 Thunder Black & Indian Red w/ Gold Head Dress
Standard equipment
Short Fenders
Two Up Seat, Black Leather
Available equipment
$499 Long Fenders
$99 White Wall Tires
$999 Billet Wheels
$99 Red Leather Seat
$99 Tan Leather Seat
$99 Leather Fringe
*Does not include delivery, setup and local taxes
1 - 1 of 1 Posts
