The Lilith Challenger - Custom 2020 Challenger Limited
Thunderstroke Accent Decals and Badges
Brave Wolf Customs accents for your Indian Thunderstroke engine
These decal inserts have a 5 inch diameter which makes them a perfect fit for the Thunderstroke engine airbox (for models with a round emblem). Check out the photos, and if your bike has the same style airbox, these are a match!
Size: 5 inch diameter circle
Weatherproof laminated decals are self adhesive. We recommend using the wet method to install these decals: A spray bottle with water and dish soap can be used to wet the surface and the back of the decal, allowing you to slide the decal into place. Once you have it aligned properly, use your thumbs to push the moisture out from behind the decal, working from the center outwards to the edges and it will adhere to your bike. Using the wet method allows the decal surface to evenly distribute over the curved surface. A hair dryer to apply heat will make the process easier since the vinyl becomes more soft and flexible when warm.
