A
Andy
·Guest
$30,999*
Larger Image Link: [link='http://www.thevog.net/Andy/photo/view/indian-chief-specifications-1/']http://www.thevog.net/Andy/photo/view/indian-chief-specifications-1/[/link]
Specifications
Note: All specifications subject to change
dimensions
Length 100.5”
Width 40.5”
Height 50.5”
Seat Height Laden 27.25”
Seat Height Unladen 27.89”
Wheelbase 68.4”
Dry Weight
(will vary for each model) 728 lbs
Running Order Weight 773 lbs
Rake Steering Head/Trail 34°/5.92”
GVW - Gross Vehicle Weight 1220 lbs
engine
Engine Type Power Plus 105, Air-Cooled
Displacement 105 Cubic Inches
Bore x Stroke 3.966 x 4.25
Compression Ratio 9 to 1
Engine Torque 100 ft*lbs (TBD)
Fuel System Closed Loop Sequential Port Fuel Injection
drivetrain
Primary Drive Chain
Gearbox Six Speed
Gear Ratio (overall)
1st 10.441:1
2nd 7.090:1
3rd 5.172:1
4th 3.984:1
5th 3.193:1
6th 2.771:1
Final Drive Belt
chassis
Frame High tensile steel, monoshock
Suspension/Front Diameter 41 mm/Travel 108 mm
Suspension/Rear Single shock/travel 73 mm
Brakes/Front Dual Caliper with Floating Rotors 11.5” Diameter
Brakes/Rear Single Caliper Floating Rotor 11.5” Diameter
Tires/Front 130/90-16 Black
Tires/Rear 150/90-16 Black
Wheels Wire spoked
Exhaust System Two Into One Stainless Steel
Electrical Instruments Tank mounted analog speedometer and muti function digital display
Charging System 42 Amps
Lamps Tear drop head lamp, glass front fender light
warranty
2 Years
pricing
$30,999*
standard colors
$0 Warrior Green Smoke
available colors
$0 Warrior Silver Smoke
standard equipment
Long Fenders
Solo Seat, Bomber Leather
available equipment
$999 Billet Wheels
* Does not include delivery, setup and local taxes
Features
Styling
Chromed tear drop Halogen Headlamp
Handpainted Pin up girl Tank Art
Die cast console - color matched
Special Edition Bomber fender cloisonne'
Special Edition Bomber front and rear fenders
Special Edition Bomber leather solo seat with bomber seat concho
Blacked out, Two into one stainless steel exhaust system with three way catalytic converter
Special Edition Bomber Saddlebags
Quick detach black fender rackPolished brake calipers
Powertrain
Blacked out Air cooled, pushrod, Power Plus 105ci engine
Closed loop, sequential, port injection with heated oxygen sensors
Six speed transmission
Chassis
Leather solo seat
5.5 gallon fuel tank
Brembo brake system with dual floating rotors and 4 piston calipers in the front and single floating rotor and two piston caliper in the rear.
Two accessory 12 V outlets
Electrical
Tank mounted analog speedometer and multi function digital display
Charging system 42 Amps
Lamps: Tear drop head lamp, glass front fender light
There are no electrical relays in the system
Note: All specificatons subject to change
