I have a 2020 roadmaster motorcycle, I had it running 2 months ago, I went to start it and no power ( it's been on a batt tender) any thoughts before I start digging for answers, bike has around 7k I bought it new, thanks.
Could jump it with a little power pack jumper unit. Can find them on Amazon. I carry one in my saddle bag, and coincidentally enough used it twice on my POV's dead battery before I had to use it in the garage when I was installing lights. I overrode the automatic shut off and ran the radio and lights hooked up to the tender thinking it was helping lol. Not when I finally went to start it. The jumper unit worked great. But check all the inline fuses from the battery tender to however you have it hooked up. Tight battery terminals and all that too. Hope it's a quick fix! I use the NOCO GB40.
As stated above... if no power at all when you push the power button, then Battery is totally dead, or bad Master Fuse or connection.
IF you get a power indication, but then nothing when you go to start etc... is it in gear?
Is it in Neutral? (in gear with the kick stand down it will not start)
