MK,
I couldn't find any pictures so I masterfully drew it up in MS Paint. lol.
Thinking about it...sealed Skateboard ball bearings may be the solution...... Not sure they make that diameter and will need longer bolts....but....
I'm thinking 2 bars that wrap around the fender and the same angle. One bar around the fender on the top of the shocks and the other on the bottom. The sealed ball bearings will be on the top bolt to allow pivot with the swing arm.
The forward part of the fender will curve down beyond the front bar about vertical and the rear part of the fender will end about 1:30 / 2:00 in clock time.
At the 1:30 /2:00 I think I would have enough room to mount a fender rack if I wanted and put a sexy suitcase on it but not detract from the 240.
As far as pictures in similar thinking the Tank machine rear fender has the wrap around bar on there fender as does the Triumph Bobber. I never messed with PS so I am not sure what all it needs.
I also have my rear indicators mounted on my shocks but if I move them to the outside of the bearings to clear the bar I might be Okay.
It's an idea,.....version 1. If you have any thoughts, comments or additions let me know or anyone for this matter.
