Just did a fluid change about 1500 kms ago. Purchased the indian 111 kit including oil and filter.
Added oil as directed which I believe was 4.5 courts and add a little more until half way between add level and full on the dipstick. When I first checked it, it seemed correct.
Leaving on a road trip in the morning so I went for a ride around the block and checked the oil. The dipstick was way at the bottom of the , almost dry.
I had 3/4 of a quart left from the kit so i dumped the rest in. Went around the block again and checked again and it's only at the add line now!!!
This is all the oil that came with the kit and doesn't seem like its enough.
Am I going to be ok on this trip? Going to be riding about 2000 kms and am afraid the engine will cease up if there is not enough oil.
Any responses tonight would help as I'm leaving early morning. Thanks.
Sent from my SM-G930W8 using Tapatalk
