I have located two connectors so far, one inside the fairing, and the other by the battery. They are both the same grey looking wire and black wire with a male end plastic connector on it. I see the grey wire comes on with the power on button. And I have already tapped in to it (since it seems I can't find a 2 wire female connector to fit But I'm looking for a way to wire my wiring harness on/off switch to come on and go off with the power button. So if I forget to turn off my additional lights I want to hook up to this wiring harness, they won't be left on. In addition, I also don't want the little green/red on off indicator on the switch to be illuminated when it's turned off, too.
I have installed a fuse block that is already hooked up to the + and - from the battery. My paper plan seems to me is all I need to do is attach the switch wire to the power on wire. Is there a direct ignition wire somewhere? I was thinking about the possibility of a fuse tap to the fuse in the fuse box for that purpose. I have a front and back camera system that I have wired in that is up and running attached to the fuse block and tapped in to that grey wire by the battery so it goes off when the bike does. I just need to run all the wires and get them shored up and hidden. And some additional front facing LED lights I mounted on the fender bolts are up and running to that grey wire in the fairing.
I have been searching for a wiring diagram but have had no luck so far. If anyone has any recommendation to get power, it's on a 2019 Roadmaster.
