1 - 20 of 29 Posts
Anyone notice a high pitch whine from the engine? I thought it might be transmission, but if I leave the bike in neutral and rev the engine, I get the same whine. It almost sounds like a turbine winding up, not like valve train noise. Any clues?
Gear whine in the cam drive
Good evening,
I have noticed some gear whine from the gear-driven primary, though nowhere as loud as on the two Victorys I owned. The primary drive gears are turning anytime the engine is running.
--- Randall
It's the supercharger lol :D
Thanks much. Will anything quiet it down? The bike is brand new, just getting ready for the 500 mile service. Heavier oil? Full synthetic?
Banned
I heard a lot of whine at first too. Pull in the clutch and listen to the tires. They make a lot of whiney noise.
I wouldn't mess with it until it's broken in. It may go away, or at least get quieter. Who knows what kind of oil they put in for break in!
Reactions: mbrewer566
Sometimes it is traced to the backseat. Slow down and it goes away!
That sounds like the rear belt; if it is slightly mis-adjusted the belt can rub against the raised edge of the pulley causing a whine. Take a look at the edge of the belt, if it is rubbing the edge will show wear.
--- Randall
Discussion Starter · #14 ·
Thanks all for the comments. The whine occurs even sitting still with the bike in neutral, so it wouldn't be associated with belt or tires. I'll mention it to the mechanic this Saturday when the 500 mile service is done, and also see how it acts after service and break-in miles are done. My Vintage has a bit of whine, but nothing near as loud, and it has a few thousand on the clock now.
Hope it is nothing, keep us posted
That whine is when two gears are rotating together and if matched properly, they will whine. Not a bad thing. Better than chain drive. My buddy's Evo does the same because it is gear drive... You'll get used to it...
--- Randall
Randall, I was hinting at the little woman on the back! LOL
Oh well, I can be a little obsessive about these things; makes me a good mechanic. Anyway, my lady tends to whoop for joy as the speed increases, but she's a wild Texas gal...
--- Randall
1 - 20 of 29 Posts
