1 - 3 of 3 Posts
I was on a ride today and noticed the high beam indicator switched on without the high beam on. I toggle the high beam on and back off to make the light shut off. After a few miles it turned back on with the high beam off ..... it’s a 2020 scout sixty bobber .... has anyone had this issue?
Never heard of this before, but the cause could be similar to the many reports of intermittent bad speed readouts. A software bug or bad connection could cause either of these issues. In the case of bad speed readouts, the solution has been to replace the dash pod under warranty.
I had a similar issue. It started after l left my bike in the rain for a whole night. The problem went away after a few hours of sun heat.
I believe that water got into the light switch and made false contact
1 - 3 of 3 Posts
