Got a chassis fault light, pulled up the error code (520320, 4) which translates to brake light shorted to ground. Checked and sure enough brake light is not coming on.
Question is, are there any easy things I can check to fix it or should I just take it to the dealership. There's only 770ish miles so well in warranty period. On the other hand it's more than an hours ride to the nearest dealership which seems a bit to go without brake lights (and if it's something I can do I prefer doing it myself anyways).
