1 - 9 of 9 Posts
Senior Member
The bike has power will start with push. No power to starter, relay clicks, swapped relays no change. Bike has 31,000 km. 18,000 mi. On vacation.
Not to be redundant, are the battery cables tight at the battery? They have an issue of working loose. Tighten them with a wrench.
What is the voltage of your battery?
What model and year of bike are you riding?
Rawhide
When you say 'no power to starter' do you means you've checked that it's not getting power to the starter motor terminal under cover (1) as in this pic?
Or do you mean 'it just wont start'?
The solenoid clicking without starting usually indicates low battery power. It might have a cell gone and it's not showing up until under high load.
Text Organism Diagram
Senior Member
FIXED it turns out to be a breakdown caused by road debris. He hit a table fork sitting on the road, it launched rearward and damage the solenoid. Managed to get it to work temp. So he made it home Thanks all and Dr shift for posting picture.
1 - 9 of 9 Posts
