FYI, you do not need to remove anything as suggested in the instructions that come with it. Simply add Loctite and reach behind the back of the stock shifter with the heel shifter in place and thread the bolts it comes with through the factory provided empty holes in the stock shifter. Super easy and mine fit and shifts fine w/o modifying the position of the stock shifter it bolts to even with the accessory chrome/rubber floorboards that are thicker.
