I have heated seats as do all Roadmasters. I have ridden in weather in the upper thirties with those seats turned on. In my opinion they are too hot. There are two heat settings and I have always used the Low setting. Last weekend I tried using the High setting thinking that maybe misunderstood the google switch position or the switch was mounted upside down. High was too hot as well. Has anyone else had this issue? If so is there a resolve? The only resolve that I have is to turn it on and then when it gets uncomfortable turn it off then back on when it cools down. That is a pain in the A__ __. No pun intended.
