1 - 8 of 8 Posts
2018 Springfield With 7700 miles. Yesterday when I started engine it stalled. I restarted and it stalled again. Third time I held a little throttle and it finally settled into normal idle so I took off. Short distance later I noticed check engine light on so returned home. Shut down and waited a minute Restarted normally and no check engine light. So I cleared the check engine code from the display and ride a couple hundred miles with no further problem. Today it started normally and everything seemed normal. Any ideas? Just a fluke?
Bone stock. Hadn’t washed it after previous ride either so don’t believe moisture problem. Otherwise this bike has been flawless.
How long had it been prior to riding it the first time? Sometimes if the battery struggles even a pinch it will trigger the check engine light.
I would ride on and keep an eye on your voltage screen at start-up and while idling to insure it is charging correctly....
Reactions: 68Lupe
There is a decompression system built into the cams to make turning the motor over a bit easier on the starter. Sometimes that system won't kick into action until the motor has gone through a full rotation and this can cause a minor hiccup. The ecm interprets the harder startup as a fault, perhaps timing or fuelling or knock sensor. That will throw a code but once the motor is up and running there is no further problem.
I had ridden a couple hundred miles a couple days prior but I agree, keep an eye on voltage. Doubt if it was low but the starter does draw a lot and it may be enough for the ECM to notice.
1 - 8 of 8 Posts
