1 - 12 of 12 Posts
Ok has anyone put 15 in or higher apes on their sixty abs model? If so what cables did you use ?
lol he still wanted to know what cables you used
Didn't use any,.....not changing my bars.
I just raised the angle of the bars and it works just fine,
But I did swap out the grips for a more comfortable set, so all is good and it only cost $17.
You only need a longer clutch cable.
But you will need longer brake hose and longer wires for the switch gear.
Don't think anyone makes a specific switch wiring kit, so you may be on your own there.
And all your brake line and clutch lines were stock? Damn gotta check this out
I used a set of brake and clutch Lines from LAchoppers just didn’t have to mess with wiring at all to get them on. But I routed the wires like factory would have to extend them to run internal
1 - 12 of 12 Posts
