1 - 8 of 8 Posts
Has anyone tried to remove hand grip on clutch side, I noticed that mine was a little lose, I could move it back and forth about 1/8 th inch.
Hi mate there is a screw in behind the rubber grip at the switch block run your finger around you will find a soft section bend back the rubber grip use a Phillips screw driver to complete the job
Thanks for the info! I just tightened my grip up and never would have known how if you hadn't posted that! Again, thanks!
Reactions: gearhead4207
Has anyone installed the Iso Grips on their Indian. I have used them previously on other bikes but the throttle cable was easy to do. Not sure about the fly by wire install. Anyone done it? Tips? TIA! Jefe
1 - 8 of 8 Posts
