Today the kind UPS man brought me my new OEM Fairing, which I've been awaiting for some time in Brilliant Blue. I went ahead and put on the 5" mid-rise windshield to go with it. For reference when you look at the pics, I have the reduced-reach handlebars.
Only two pics for now.... It was getting dark when I got done and I was anxious to go for a ride, then when I got home my garage was too dimly lit to take any more tonight. Please ask any questions and I'll try my best to answer!
First, observations on fit and finish:
The fairing is made out of thick material, I think it's aluminum. Nice and sturdy, you're not going to bend it and crack the paint by mistake when installing it. Paint color was a perfect match. The entire fairing (both sides) is body color. The cutout for the headlight doesn't align perfectly, my headlight looks to be about 1/4" low in the hole, but that's not a big issue. The "gasket" that goes around the headlight is floppy and a bit difficult to install. I'm also not sure if it's entirely necessary (I'm thinking that a gap there for air to flow through might prevent turbulence, that's an experiment for later).
My biggest disapointment was that my Leatherworks tool bag was just about 1/2" too wide to fit between the supports for the fairing, so I had to adjust it's mounting. Later on I might get her to make me a bag that's an inch or two narrower.
Second, observations after a brief ride:
I went for a brief ride at speeds around 55 mph and everything felt good. With the 5" windshield, the wind hits me a couple inches above where it did with my Marlin flyscreen. Not sure if that's good or bad. It hits me about neck level which means I feel less pressure on my chest, but it's a bit more noisy of a ride. Even with the RR bars on and the mismatch in alignment between fairing and handlebars, I do feel some reduction in wind hitting my hands, which is also good. At 55 mph I didn't experience any buffeting or turbulence, the airflow felt good to me. Saturday I'll be going on a 200 mile ride at interstate speeds so I'll have more to report then.
