1 - 3 of 3 Posts
Several weeks ago the demo trailer was at my local Indian dealer. Rode everything they had including several 2020 Scout. Noticed the gear indicator doesn't go away with the clutch pulled in. Does anyone know if this is hard wired into the bike or can my 2018 be updated to do the same thing.
I would guess that the dashboard display is determined by the ECU and not the clutch cable itself, so it's probably not something you can adjust on your 2018 Scout. Though if my assumption is incorrect, maybe there's a sensor button on the clutch cable which detects when it's pulled in that you can delete? If so, I would think that would achieve your desired result.
My guess is there's a position sensor inside the transmission. Works much better than the engine speed/wheel speed algorithms.
1 - 3 of 3 Posts
