So here we are, roughly 6 years into the Indian Motorcycle resurrection via Polaris and they've officially puffed out their chests with a fully developed standalone high performance motorcycle, their first focused attempt at taking on the international market. Opinions aside, lets take a look at the numbers and how it stacks up against the competition on paper.
The OP will start at the high end for each manufacturer (budget model comparison another day), we'll use crank horsepower/wet weight to calculate power:weight ratios because it's very difficult to find reliable stock dyno data for every bike on this list. Just keep in mind that on the street, for all of these bikes, there will be various drivetrain losses and the horsepower measured at the wheel will almost always be at least 10% lower than the horsepower listed by the manufacturer (measured at the engine). This is meant to be a basic numbers based overview of how the new Indians stack up against the competition, I'm not going to dive into rake, trail, wheelbase, seat height, battery, GVRW, fuel capacity specs etc, potential buyers that personally find that information crucial can find it if they want it. This is a basic "how much does it cost, how fast does it go, and how complicated are the electronics" comparison. All specs are taken from the manufacturer, I will note any exceptions.
To make this wall of text easier to digest:
Specifications that exceed the ability of the FTR 1200 S will be marked in green.
Specifications that lag behind the ability of the FTR 1200 S will be marked in red.
Specifications that are a matter of personal preference will be left black.
2019 FTR 1200 S
MSRP $15,500 USD
Wet Weight
518 lbs
Engine Type
Liquid Cooled, V-Twin, DOHC, 4-Valves per Cylinder
Displacement
1203 cc
Horsepower
120 HP
Peak Torque
85 ft-lb (115.2 Nm)
Power:Weight Ratio (hp/lb)
4.3:1
Lean Angle
43 degrees
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
Fully Adjustable Inverted Telescopic Cartridge Fork
5.9 in (150 mm) travel
Rear Suspension
Fully Adjustable Piggyback IFP mono-shock
5.9 in (150 mm)
Brakes
Front Brakes:
Dual 320mm x t5 Rotor with 4-Piston Brembo Calipers
Rear Brakes:
Single 265mm x t5 Rotor with 2-Piston Brembo Calipers
Tires / Wheels
Front Tire:
Dunlop® DT3-R Radial, 120/70R19 60V
Rear Tire:
Dunlop® DT3-R Radial, 150/80R18 70V
Electronics & Rider Aids
4.3” Ride Command LCD Touchscreen w/ Bluetooth
3 Ride Modes (Sport, Standard Rain)
Lean Angle Sensitive ABS
Stability, Traction and Wheelie Mitigation Control
USB Fast-Charge Port
Standard ABS
Cruise Control
LED Headlight, Taillight, Turn Signals
"Heritage" Standards & Scramblers
2018 Ducati Scrambler 1100 Sport
Viper Black
MSRP $14,995 USD
Wet Weight
454 lbs
Engine Type
L-Twin, Air Cooled, Desmodromic Valves, 2 Valves per Cylinder
Displacement
1,079 cc
Horsepower
86 HP
Peak Torque
65 ft-lb
5.3:1
Lean Angle
Not Listed
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
Fully Adjustable Inverted Ohlins Fork
Rear Suspension
Fully Adjustable Ohlins mono-shock
5.9 in (150 mm)
Brakes
Front Brakes:
2 x Ø320 mm semi-floating discs, radially mounted Brembo Monobloc M4.32 calipers, 4-piston
Rear Brakes:
Ø245 mm disc, 1-piston floating caliper
Tires / Wheels
Front Tire:
Pirelli MT 60 RS 120/70 ZR18
Rear Tire:
Pirelli MT 60 RS 180/55 ZR17
Riding Modes
Power Modes
Ducati Safety Pack (Cornering ABS + DTC)
LED lights
LCD instruments
Under-seat storage compartment with USB socket
2018 BMW R nineT
MSRP $15,495 USD
Wet Weight
489 lbs
Engine Type
Flat Twin, Air/Oil Cooled, DOHC, 4 Valves per Cylinder
Displacement
1,170 cc
Horsepower
110 HP
Peak Torque
85.6 ft-lb
4.4:1
Lean Angle
45 degrees
Transmission/Drive
Hydraulic Clutch
Shaft Drive
Front Suspension
Inverted telescopic forks
4.7 in
Rear Suspension
BMW Paralever (adjustable)
4.7 in
Brakes
Front Brakes:
Double disc. ABS. Four-piston calipers.
Rear Brakes:
Single disc. ABS. Floating disc. Two-piston calipers.
Tires / Wheels
Front Tire:
120/70-ZR17
Rear Tire:
180/55-ZR17
ABS
2018 Triumph Thruxton R
MSRP $15,000 USD
Wet Weight
468 lbs
Engine Type
Liquid cooled, 4 Valve per Cylinder, SOHC, 270° crank angle parallel twin
Displacement
1200 cc
Horsepower
97 HP
Peak Torque
82.6 ft-lb
4.8:1
Lean Angle
50 degrees
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
Fully adjustable Showa inverted forks
4.7 in
Rear Suspension
Fully adjustable Ohlins twin shocks with piggy back reservoir, 120mm rear wheel travel
4.7 in
Brakes
Brembo twin 310mm floating discs Brembo 4-piston radial monobloc calipers, ABS
Single 220mm disc, Nissin 2-piston floating caliper, ABS
Tires / Wheels
120/70 ZR 17
160/60 ZR17
LCD multi-functional instrument pack with analogue speedometer
LED lights
Analogue tachometer
Heated grip ready
Traction control
Throttle modes
USB socket
Immobilizer
2019 Kawasaki Z900RS Cafe
MSRP $11,699 USD
Wet Weight
474 lbs
Engine Type
Liquid-Cooled, Inline-4, DOHC, 4 Valves per Cylinder
Displacement
948cc
Horsepower
110 HP
Peak Torque
72.7 ft-lb
4.3:1
Lean Angle
Not Listed
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
Adjustable inverted forks
4.7 in
Rear Suspension
Adjustable horizontal mono-shock
5.5 in
Brakes
Twin 300mm 4-piston radial calipers, ABS
Single 220mm disc, 2-piston caliper, ABS
Tires / Wheels
120/70 ZR17 Dunlop GPR-300F
180/55 ZR17 Dunlop GPR-300
LCD multi-functional instrument panel
LED lights
Traction control
ABS
Modern Sport Standards & "Nakeds"
Ducati Monster 1200 S
MSRP $17,295 USD
Wet Weight
465 lbs
Engine Type
L-Twin, Liquid Cooled, Testastretta 11 degree, 4 Desmodromic Valves per Cylinder,
Displacement
1198 cc
Horsepower
147 HP
Peak Torque
91 ft-lb
3.2:1
Lean Angle
50 degrees
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
Fully adjustable Ohlins inverted forks
5.1 in
Rear Suspension
Fully adjustable Ohlins mono-shock
5.9 in
Brakes
2 x 330 mm semi-floating discs, Brembo Monobloc Evo M50 calipers, 4-piston, ABS
245 mm disc, 2-piston caliper, ABS
Tires / Wheels
Pirelli Diablo Rosso III 120/70 ZR17
Pirelli Diablo Rosso III 190/55 ZR17
TFT Display
Cornering ABS
Ducati Traction Control
Ducati Wheelie Control
Riding Modes
LED Lights
2018 Honda CB1000R
MSRP $12,999 USD
Wet Weight
467 lbs
Engine Type
Liquid-Cooled, DOHC, In-line 4, 4 Valves per Cylinder
Displacement
998 cc
Horsepower
143 HP
Peak Torque
76.7 ft-lb
3.3:1
Lean Angle
Not Listed
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
Adjustable Showa inverted forks
4.3 in
Rear Suspension
Adjustable Showa mono-shock
5.2 in
Brakes
Dual radial-mounted four-piston calipers with full-floating 310mm discs; ABS
Single-caliper 256mm disc; ABS
Tires / Wheels
120/70 ZR17
190/55 ZR17
Riding Modes
ABS
2019 Yamaha MT-10
MSRP $12,999 USD
Wet Weight
463 lbs
Engine Type
Liquid-Cooled, DOHC, Inline 4
Displacement
998cc
Horsepower
160 HP
Peak Torque
82 ft lb
2.9:1
Lean Angle
Not listed, but lots
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
43mm KYB® inverted fork, fully adjustable
4.7 in
Rear Suspension
KYB® piggyback shock, fully adjustable
4.7 in
Brakes
Hydraulic dual disc, Ø 320 mm
Hydraulic single disc, Ø 220 mm
Tires / Wheels
120/70ZR17
190/55ZR17
LCD Display
YCC-T
Riding Modes (3)
Traction Control
Cruise Control
2018 Ducati Hypermotard SP
MSRP $16,295 USD
Wet Weight
443 lbs
Engine Type
Displacement
937 cc
Horsepower
113 HP
Peak Torque
72 ft lb
4:1
Lean Angle
47.5 degrees
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
Öhlins fully adjustable 50mm usd forks
7.3 in
Rear Suspension
Fully adjustable Öhlins monoshock
6.9 in
Brakes
2 x 320 mm Brembo 4-piston, ABS
Tires / Wheels
Pirelli Diablo Supercorsa SP, 120/70 ZR17
Pirelli Diablo Supercorsa SP, 180/55 ZR17
LCD Display
Riding Modes
Power Modes
Ducati Safety Pack (ABS + DTC)
Carbon fibre components
2018 KTM Super Duke 1290 R
MSRP $17,999 USD
Wet Weight
459 lbs
Engine Type
LC8 75 degree V-Twin, Liquid Cooled, 4 Valves per Cylinder,
Displacement
1301 cc
Horsepower
177 HP
Peak Torque
104 ft lb
2.6:1
Lean Angle
Not listed, lots
Transmission/Drive
Quickshifter
Slipper Clutch
Chain Drive
Front Suspension
Fully adjustable WP 48mm usd forks
4.92 in
Rear Suspension
Fully adjustable WP monoshock
6.14 in
Brakes
Tires / Wheels
Metzeler M7RR
120/70 ZR17
190/55 ZR17
LCD Display
Riding Modes
Lean-Angle Sensitive ABS
Cruise Control
Traction Control
TPMS
Bluetooth
Stay tuned. More comparisons to come (Yamaha, KTM, Suzuki etc).
2019 FTR 1200 S
MSRP $15,500 USD
Wet Weight
518 lbs
Engine Type
Displacement
1203 cc
Horsepower
120 HP
Peak Torque
85 ft-lb (115.2 Nm)
4.3:1
Lean Angle
43 degrees
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
Rear Suspension
5.9 in (150 mm)
Brakes
Front Brakes:
Rear Brakes:
Tires / Wheels
Front Tire:
Rear Tire:
Standard ABS
Cruise Control
Viper Black
MSRP $14,995 USD
Wet Weight
454 lbs
Engine Type
Displacement
1,079 cc
Horsepower
86 HP
Peak Torque
65 ft-lb
5.3:1
Lean Angle
Not Listed
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
Rear Suspension
5.9 in (150 mm)
Brakes
Front Brakes:
Rear Brakes:
Tires / Wheels
Front Tire:
Rear Tire:
Riding Modes
Power Modes
LED lights
LCD instruments
2018 BMW R nineT
MSRP $15,495 USD
Wet Weight
489 lbs
Engine Type
Displacement
1,170 cc
Horsepower
110 HP
Peak Torque
85.6 ft-lb
4.4:1
Lean Angle
45 degrees
Transmission/Drive
Hydraulic Clutch
Shaft Drive
Front Suspension
4.7 in
Rear Suspension
4.7 in
Brakes
Front Brakes:
Rear Brakes:
Tires / Wheels
Front Tire:
120/70-ZR17
Rear Tire:
180/55-ZR17
ABS
MSRP $15,000 USD
Wet Weight
468 lbs
Engine Type
Displacement
1200 cc
Horsepower
97 HP
Peak Torque
82.6 ft-lb
4.8:1
Lean Angle
50 degrees
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
4.7 in
Rear Suspension
4.7 in
Brakes
Tires / Wheels
120/70 ZR 17
160/60 ZR17
LED lights
Analogue tachometer
Heated grip ready
Traction control
Throttle modes
USB socket
Immobilizer
MSRP $11,699 USD
Wet Weight
474 lbs
Engine Type
Displacement
948cc
Horsepower
110 HP
Peak Torque
72.7 ft-lb
4.3:1
Lean Angle
Not Listed
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
4.7 in
Rear Suspension
5.5 in
Brakes
Tires / Wheels
LED lights
Traction control
ABS
MSRP $17,295 USD
Wet Weight
465 lbs
Engine Type
Displacement
1198 cc
Horsepower
147 HP
Peak Torque
91 ft-lb
3.2:1
Lean Angle
50 degrees
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
5.1 in
Rear Suspension
5.9 in
Brakes
Tires / Wheels
TFT Display
Cornering ABS
Riding Modes
LED Lights
2018 Honda CB1000R
MSRP $12,999 USD
Wet Weight
467 lbs
Engine Type
Displacement
998 cc
Horsepower
143 HP
Peak Torque
76.7 ft-lb
3.3:1
Lean Angle
Not Listed
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
4.3 in
Rear Suspension
5.2 in
Brakes
Tires / Wheels
120/70 ZR17
190/55 ZR17
Riding Modes
ABS
2019 Yamaha MT-10
MSRP $12,999 USD
Wet Weight
463 lbs
Engine Type
Displacement
998cc
Horsepower
160 HP
Peak Torque
82 ft lb
2.9:1
Lean Angle
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
4.7 in
Rear Suspension
4.7 in
Brakes
Tires / Wheels
120/70ZR17
190/55ZR17
LCD Display
YCC-T
Riding Modes (3)
Traction Control
Cruise Control
MSRP $16,295 USD
Wet Weight
443 lbs
Engine Type
Displacement
937 cc
Horsepower
113 HP
Peak Torque
72 ft lb
4:1
Lean Angle
47.5 degrees
Transmission/Drive
Slipper Clutch
Chain Drive
Front Suspension
7.3 in
Rear Suspension
6.9 in
Brakes
Tires / Wheels
LCD Display
Riding Modes
Power Modes
MSRP $17,999 USD
Wet Weight
459 lbs
Engine Type
Displacement
1301 cc
Horsepower
177 HP
Peak Torque
104 ft lb
2.6:1
Lean Angle
Not listed, lots
Transmission/Drive
Quickshifter
Slipper Clutch
Chain Drive
Front Suspension
4.92 in
Rear Suspension
6.14 in
Brakes
Tires / Wheels
Metzeler M7RR
120/70 ZR17
190/55 ZR17
LCD Display
Riding Modes
Cruise Control
Traction Control
TPMS
Bluetooth
