Like I need another motorcycle......which I do.
I have been following the new FTR 1200 Rally bike and really like what I am seeing. First off, I know it is Not a dirtbike but I really like the styling. I put together a list of options I wanted and submitted it a couple of stealers in my local area. Most do not really know a lot about the new Rally model. The build sheet I submitted has had few returns for a build quote with an out-the-door price.
Wichita stealer vaguely sent back a very soft price if $17k+ after having to break it down for him "barney" style....wow!
There are a couple of nice youtube reviews out there on the ride and performance.
2020 Indian FTR Rally Spec
PRICE $13,499 US / $16,499 CAN
ENGINE 1,203cc, DOHC, 60-degree V-twin; 4 valves/cyl.
BORE X STROKE 102.0 x 73.6mm
COMPRESSION RATIO 12.5:1
FUEL DELIVERY Closed-loop fuel injection
CLUTCH Constant mesh/multiplate slip and assist clutch
TRANSMISSION/FINAL DRIVE 6-speed/chain
CLAIMED HORSEPOWER 123 hp @ 8,250 rpm
CLAIMED TORQUE 87 lb.-ft. @ 5,900 rpm
FRONT SUSPENSION 43mm fully adjustable inverted cartridge fork; 5.9-in. travel
REAR SUSPENSION Monotube IFP; 5.9-in. travel
FRONT BRAKES 4-piston Brembo M4.32 calipers, dual 320mm
REAR BRAKE 2-piston Brembo P34 caliper, 260mm
TIRES, FRONT/REAR Pirelli Scorpion Rally STR; 120/70R-19 / 150/70R-18
RAKE/TRAIL 26.3°/5.1 in.
WHEELBASE 60.0 in.
SEAT HEIGHT 33.6 in.
CLAIMED DRY WEIGHT 511 lb.
GROUND CLEARANCE 7.2 in.
FUEL CAPACITY 3.4 gal.
Stock Photo:
Below is from my build sheet with what I wanted and the color. I added the following options.
Model Selected: N20RTT22A9
Additional Accessories:
2883500-FBA K-SIDEBAG MSGR BLK
2883501-581 K-FENNDER FRONT SLVR
2883502-581 K-FENDER REAR SLVR
2883506 K-WINDSCREEN MID
2883511 K-LUGGAGE RACK
2883516 K-SIDEBAG MOUNT
2883768 K-RADIATOR GUARD
2883842 K-BRKT REAR MOUNT
2884100 K-GRIPS PROTAPER
2884101 K-MOUNT PHONE RAM
2884143-1807 K-CVR AIRBOX PEARL WHT
2884156 K-TURN SIGNAL CLR
Other load out I like but $22,000+.....Jesus
WHEELBASE 60.0 in.
Stock Photo:
