1 - 13 of 13 Posts
2014 chief classic
The trim on my 2014 classic looks like it has a plastic coating on it that is delaminating. I don’t see any rust. Is this a common thing? Is there an easy way to remove the rest of the plastic? Once plastic is removed is there special care to be taken on the trim piece?
Thanks!!
It's just cheap stick on trim available at most auto parts stores.
When it falls apart, pull it off, clean up with a little paint thinner and apply new trim.
I got mine at AutoZone. A whole roll will do the bike a couple times.
2014 chief classic
Sounds easy to repair. Someday I will have it painted on.
Thanks!
2018 Indian Chief, "Adeline"
I've been looking for someone who makes a stainless aftermarket fender for when the time comes for me. I haven't found anything, yet, but maybe others have? TBH, I'd love one with chromed lines, and a deeply scalloped shape more like a Gilroy fender. Until then, glad i saw this thread.
A little hint from me on applying the new 3/4" trim:
Remove your fender (quite easy) and lay it on its side on a towel.
Warm the trim with either a good hairdryer or a heat gun to get the nice smooth curve.
Even if you go to your dealer and get screwed for $79 per fender for "Indian" trim (exactly the same stuff at AutoZone), you will have to bend it yourself.
Spend $20 and have enough to do it all.
The acute angle at the ends should be cut after the trim is installed --- very carefully, using a new blade in a utility knife. I slipped a thin strip of something just under where I was cutting to prevent marring the paint.
While your fender is off, I HIGHLY recommend cleaning the underside with paint thinner and applying a good coat of rubberized undercoating to prevent the rust that forms at the weld seams.
I had both of my fenders rust out pretty bad.
All in all, an easy, painless project.
I don't think there has been a one-piece version for the fender made as of yet. Likely due to high cost of manufacture. The challenge with this is it's a three piece fender and the strip is there to hide the seams and spot welds. I hated the look of it from day one, so when I had my Vintage and RM repainted, I had my painter lead-fill the seams and smooth it out. It's an old-school technique. Not many people are still using it these days due to the ease of body fillers. Plus, just doing a body filler would likely crack over time.
It can be welded as well, but that takes a very skilled welder to ensure the right heat is applied to avoid warpage.
Very surprised that Kuryakyn has not come out with a one piece wheel trim that is molded. I think it would sell better than most of the other stuff they offer for the Indian. Dean
A buddy of mine back in Charleston, SC did chops of VW bugs, Hudsons, etc, and often lead-filled the body panel seams. He did fantastic work. Also, didn't know that about the indian fenders. I love love love a scalloped fender in general, but felt Polaris could have done a bit better. To your point, though, it'd certainly increase cost. Pity it wasn't available as a premium option or some such.
That said, like Dean mentioned, surprised Kuryakyn...really nobody has produced a one-piece.
That guy does sell them on the Indian Motorcycle Facebook groups. I have seen photos posted on Facebook of his satisfied customers' bikes.
1 - 13 of 13 Posts
