Just sharing something about the screws that hold on the chin fairing in front of the battery, use a torque wrench!!! The tech spec's call for 36 inch pounds, that's not a lot. The brace that holds the fastners is plastic and what you have is a brass insert pressed into the plastic. If you over tighten it the brass insert will begin to spin and it isn't coming out. The chin fairing and the radiator grill are both plastic too. No way to reach in without bending and pulling up the chin fairing and removing the screw holding the brace and unscrewing the two screws at the top of the radiator grill and taking out as an assembly. Cost me a new chin fairing and the brace. The brace was about $20 and so was the chin fairing.
