So I took my headpipe and cat off, sent to American Customs, refitted and I swear it is just as hot if not hotter? It will actually get red hot going around the block. Here is the thing, I put the slightest dent in the rear downtube as I was trying to remove it, so I am thinking this tiny restriction may be causing it to heat up. So, trying again..... Do not want anything where I am cutting the pipe like a jackpot header or others. If you have one with the cat already removed, I am looking for professionally done ones only. Thanks
