1 - 8 of 8 Posts
Trying to remove the stock foot pegs. There is a super tiny clip holding the pin in place. Any idea how to get it off? Anyone else have this problem? Every other motorcycle manufacturer on the planet uses a simple cotter pin on their foot pegs.
Well, that was a pain in the ass, but I got it done. Way to make a ten minute job take an hour Indian! LOL
Thanks for the tips everyone! I'm absolutely loving this bike!
Just run a small file across the “clip”. It will catch the edge and then you can easily pull it off with needle nose pliers.
I just did my pegs not to long ago , the tiny clip is basicly a mini key ring . I rotate it so you can see both ends then I took two angled picks , put one on each end and push away from each other if that makes sense and u will be able to roll one off since ur holding pressure the opposite way on the other one . That was the only way I could get them off easy
1 - 8 of 8 Posts
