1 - 6 of 6 Posts
As per the photo, you can see the issue. There is some fog inside of my MT-15 speedometer. First, there was some dust inside of it then I have opened the speedo and cleaned that. While assembling the 2 part of the casing I have used a thermal solution in the joint, My thought was if I do that there will be no dust inside of it anymore. I was right, now there is no dust but there is fog only when my bike is running only. After switched off my bike it vanished in 5 minutes. When again started the bike it comes gently and seems like 1/3 of the speedo. Can anyone help me how can I fix this?
And If I am going to change the Speedometer Can I use the R15 V3 one to my MT 15?
@bappymac
Your bike is an Indian COUNTRY variant of Yamaha.
This forum is Indian BRAND of motorcycles.
Your best bet is to find a Yamaha forum.
Try
Or
If you are still on here looking, you may want to remove some of the joint sealer you put on. There is usually a very small hole in the bottom of gages to allow moisture to evaporate.
1 - 6 of 6 Posts
