My 2014 vintage makes a fluting/whistling sound when cold mostly goes away when warmed up and cruising. Anyone have this or had to deal with it? Just wondering if it needs some exhaust tightened or sucking air somewhere?
From the manual: said:Cleaning the drive belt will maximize belt and sprocket life and minimize drive line noise. Clean the belt at every tire change. Clean the belt more often if riding in dirty, dusty or high debris environments.
1. Mix a few drops of mild dish soap with a cup of warm water.
2. Use a soft nylon brush to clean the belt and sprocket teeth with the soapy water. Clean well in corner areas where road debris and belt dust can collect.
3. Rinse the belt with clear water, then dry thoroughly.
