Not only is it a really great shield, but it'd be hard to find someone who works with you as well as John does. I highly recommend Freedom Shield.I have a 16" Freedom Shield. It's also a little wider than stock. I raise it a bit at highway speeds but I can still see over it. Lighter weight bugs are lifted up and over. Heavier ones will still hit you. I lower it at slower speeds. The flip part has some distortion but it's not bad. The best feature is the test ride. As long as you leave the protective cover on it, you can send it back if you don't like it.
Others may have advice on your question, but you might consider calling the folks at Freedom and see what they have to say. As another poster mentioned, they let you install their windshield and use it to see how it suits you. If for any reason you don't like it, it can be returned. The only caveat is that you must leave the protective film on to do this. My guess is that for you a 'flip' windshield at your current height would work since the whole idea of the recurve is to divert air flow more than a standard of the same height. BTW - Nice RM!I have really enjoyed my stock windshield. However I am 6' tall, and at hwy speed I have it lifted all the way. Unfortunately I have recently added an air hawk to my seat due to its unbearable pain after 150 miles or so. Now with the air hawk my head is in the turbulence zone with the windshield all the way up. With that situation what are my best options. Also I worry about the turbulence for my wife behind me. Would a taller straight shield be better or would a flip give us more clearance?
I have a Klock flip. I ordered a Indian tinted but it had very little tint I like the klockAny thoughts/advice on flip windshields. Im considering getting one. I'm favoring the Klock Werks 12" flip; however, I'm not sere if that's as good or better than the one put out by Indian. Any help would be appreciated.
I am 6' and with my air hawk it raises me up a little. My stock windshield is maxed out and I notice a little turbulence at the top of my helmet. That I didn't notice without the air hawk. So that 1 inch maybe makes a difference. So I don't know if the flip out windshield of the same height will fix the problem or if a taller windshield will be required. A buddy of mine bought a flip out and put his stock glass back on after being disappointed with it. As it created so much turbulence for his passenger that her helmet shook so much that it blured her vision.I had the Indian version (they are made by KW) and it worked OK. I am 6'1" and it had to be almost all the way up to provide the right level of protection for me. I got the 14" LRS Battle Axe an it's perfect for me. The LRS isn't the same thickness as the KW and is more prone to nicks and scratches, but at the price, it's almost like getting a two for one.
