Hey all,
thanks in advance for any help. I know there are some other discussions about this but they seem to be unresolved.
was wondering if anyone had any information when using the illuminator module from badlands (Ill-ind-s). I recently deleted my rear fender and wanted to install some Led Run/brake/turn signals to replace the stock setup.
I installed all my wires, followed all the instructions which were pretty easy, and connected the module to the battery.
When I turned the lights on I had no turn signal function, and the brake lights immediately turn on. when I disconnect the module from the battery, the lights do function properly but they are dimmer than what they should be.
do I need resistors in order for this to work? Is there an easier way to install new run/brake/turn signals in the rear without using the stock tail light?
I appreciate any help! Thanks!
Dave
Dave
