1 - 7 of 7 Posts
I have a 2017 chieftain whose fairing compartment door has snapped off. (The little plastic piece is also broke, but that's an easy fix). Has anyone on here tackled it? If so, is it something a novice can do?
TIA!
Bronze Member
Post #5 tells how to replace them
Post #43 shows where to get replacements clips.
TIA!
I replaced mine because it warped due to the heat. IIRC, it just snaps in and out.
TY... all 4 plastic pieces that act as hindges are snapped off. I wasn't sure if I had to somehow push the medal pins thru a hole....
1 - 7 of 7 Posts
