Yup, the vents are open. Bike feels like it’s operating totally normal. I’m in St Augustine and temps are 93, and humidity is down to 51. Feels no different. Anyway, just made my last gas stop and beer cooler visit. We’ll figure it out one way or another!Low coolant in the reservoir does NOT mean low coolant in the system. The fact that topping it off did not reduce the heat and the temps at 184-185 AND 211 at a stop tells me the cooling system is functioning properly. I assume you have the fairing vents open to allow more airflow to you?
Yup, feel that with my soft lowers. Outstanding in the winter (I don’t even need to use my heated boot liners!), but those puppies came off by March! 👍I feel like that with my soft lower close outs on when it’s warm out. Not like pass out but def warm/hot air swirling around my legs and feet. It gets ‘satan’s taint’ hot out here too
I appreciate it, and will go delete my poor take. Your comment was spot on I think. 🤦♂️No harm. Sometimes my dry sense of humor gets me in troubleHope the heat issue gets resolved
Good point. I was wearing a pair of Dainese riding pants - thin/stretchy, and they have vents in the legs to let air in. I don’t think that part is particularly effective. One thing I know for sure is my mesh jacket is a size too big, and the material folds over itself in spots, eliminating the benefit of the mesh. Def time to shop for new threads!Just something else to think about is your pants material. I bought some wrangler jeans with spandex in it which makes them more stretchy which in turn makes them more comfortable but spandex is a type of plastic and not considered a good insulator and will transfer more heat directly to your ankle/skin then a pair of 100% pure cotton jeans.
Tim
Yup! I think someone said earlier if you don’t have to take a leak all the time you’re not drinking enough! Likely what happened to me this trip!When it's that hot make sure and stop a little more often to hydrate. Bottled water or maybe Gatorade or similar sports drink will do. Pushing yourself for too long will only make things worse for you.
I appreciate everyone’s input! I feel old! 🤦♂️🤣Hydration is key to comfort and survival, BUT keeping our core temperature down is of paramount, and that INCLUDES our coconut. COLD.if not ICE COLD liquids are a must, room temp liquids do nothing to bring our body temp down. My go to fullface helmet for my sportbike is black and it's kinda warm but my noggin is out in the breeze, albeit hot. But riding my first cruiser 12 years ago, even with a black open faced half helmet I felt my brain was gettin fried. AS SOON as I started wearing a white helmet that feeling was reduced quite a bit, and the white color helps me to visibly stand out better to others.
This has been a great thread where we have come together as a "fellowship" to help a member, but in the end we are ALL helped.This I fear is gonna be a brutal summer as it's hotter down here in S. Fla than normal and I'm a year older, we gotta remember, at least for me, one year older and I feel it.
RACNRAY
richer combustion that is and no heat collector and new tuneI'm not a Challenger owner, so this may or may not be relevant. Installed an entire Rinehart system on my 2016 Chieftain, getting rid of the CAT dropped temps 60+ degrees. Not sure how much that would help a Challenger, it probably would cool down the exhaust heat where the CAT is or isn't
I too removed my snarky comment/response.I appreciate it, and will go delete my poor take. Your comment was spot on I think. 🤦♂️
Hence my trusty cooler rack. After getting stuck on I10 in traffic in Houston a few years ago. 102 deg/100% humidity I swore I’d never be without water again. A soaker vest and cap under the helmet does wonders, if only for 90 minutes or so. By then it may be time to stop and wet everything down again. I’ve gone so far as to throw a 10lb bag of ice over my lap.Hydration is key to comfort and survival, BUT keeping our core temperature down is of paramount, and that INCLUDES our coconut. COLD.if not ICE COLD liquids are a must, room temp liquids do nothing to bring our body temp down.
RACNRAY
Yep it even gets hot up here in Wyoming. My ‘21 Challenger runs at least as cool as the ‘13 Gold Wing. Stage 1 exhaust, cat still in place, see no need to remove it because heat on the lower extremities has not been an issue for 13k miles. I rode in triple digits last summer in California. Close to triple digits and high humidity in the south east ie….Ky, NC, SC,Ga and had no ill effects. And coming from Wyoming I’m not acclimated.Yup, the vents are open. Bike feels like it’s operating totally normal. I’m in St Augustine and temps are 93, and humidity is down to 51. Feels no different. Anyway, just made my last gas stop and beer cooler visit. We’ll figure it out one way or another!
I use a camelback backpack that keeps my liquid of choice, usually Gatorade cold for 12 hrs. I strap it on backseat and run straw/tube over my shoulder and it has a clip to keep it there. Definitely a must on long trips especially in the heat down southHence my trusty cooler rack. After getting stuck on I10 in traffic in Houston a few years ago. 102 deg/100% humidity I swore I’d never be without water again. A soaker vest and cap under the helmet does wonders, if only for 90 minutes or so. By then it may be time to stop and wet everything down again. I’ve gone so far as to throw a 10lb bag of ice over my lap.
