dont do much night riding but will see if mine does this, tomorrow night! damn! that aint rightFwiw don't spend a bunch of.money on a tuner to fix it. It won't. Even the pcvx with a fuel Moto tune doesn't fix it. It's a normal thing on these bikes. I'm thinking the head pipes aren't thick enough.
I would have to agree with this. This is something I have had since day one. I bought the PVCX and tried both the fuel moto tune and the dyno jet tune but it still glowed red around 60mph in 6th gear just above 2k rpms. If I throttled out of that range the glowing would stop within 10 seconds or so. Since I had the glow stock and with the tunes I proceeded to just drive it. I did some tuning with the powercore and craigs equations and it lessened some but not much. Fast forward about 2k miles and I checked the exhaust gasket. It was leaking. I changed it and it still glowed red but not quite as much as before.Exhaust headers turn red in the dark. It's not because of cheap metal or lean fuel mixtures. Steel looks red in the dark anywhere between 400 - 700 degrees F, which is well with the normal range of exhaust gas temps at the head.
It is not because of lean conditions; if anything, it happens more when the mixture is too rich and there is still some combustion going on in the exhaust stream.
By the way, uncompressed gasoline auto-ignites at about 535 degrees F.
