1 - 12 of 12 Posts
Hello,
i just bought a 2021 scout after 4 years with a sixty and 6 months with a bobber (my god, it is not manageable for me under the rain !).
On my 21, there is no engine temp indicator. Is it normal ?
612274
“Digital tachometer, odometer, trip meter, engine temp and low fuel lamp”
As said in the specifications.
Since you’ve had a previous Scout I’m guessing you know how to use the toggle switch.
Is there a blank 4th display, or does it seem to be skipping past temperature?
I also have a 2021, according to the dealer Indian removed the Engine temp function from the MFD. Didn't know why.
I’m curious, do you have a voltage display?
If so, makes me wonder if that’s why temperature wouldn’t be there now. Just keeping 4 toggle displays.
There’s an online article showing the functions of the Scout gauge. It says the following:
“Battery voltage displays real-time battery voltage (V). This will increase while the engine is running, due to the alternator.”
I’ve never seen voltage on my 2015 Scout, although that portion of the article talks about how to select Miles/Kilometers and settings with engine off.
I’ve never done that so maybe that’s the way to see it.
German Rider
2020 Scout ICON got total milage, Trip, RPM, water temp, voltage.
Cu,
Sven
1 - 12 of 12 Posts
