I used the Fiebing wax to coat mine after staining. Put it on, then lightly heated it with a heat gun, rubbed it down, then re-coated it. Keep in stock after long wet rides or any harsh weather. You will love the results.Thanks man That's exactly what I did. Unhooked the back of the bib then slid a wally world bag under it. Thanks again. I am very happy how they came out. I used the Fiebing saddle tan oil base. One coat is all it took. Now I have to put on the resolene protectant. Thanks again
I didn't remove the bib, just placed a rag between it and the tank and dyed normally.Trying to dye my bags and seat .
Can you provide me the detailed steps you took to dye your leather? I also see that different people are using different methods of finishing such as resolene or wax? If there a preference or a big difference?View attachment 5536 View attachment 5537 View attachment 5538
Dyed mine last weekend, left the bib on, put plastic under it while dying.
Resolene was the product that Fiebing reccomended, There is an excelant video on U tube. That is what I followed. First pour the Fiebing #12 deglazer cleaner on a clean sponge wipe the leather in straight strokes. Do not rub in circular motion. Cover all leather areas wipe off any access and let set for 30 minutes. Apply one coat of Fiebings professional oil dye (saddle tan). Keep sponge moving and blend color do not let a puddle, run, or sploch form. The dye will blend to a uniform color. I only needed one coat and I let it dry overnight. Three coats of Resolene. I used a damp sponge to apply the resolene. Again straight strokes no circular motions and be sure to cover all the leather surface. I waited one hour between coats and over night after the third coat. I put the leather back on the next day. It is not that hard to do. Take your time and you will be amazed. This is the first time I did any dyeing of anything and no one could have done a better job.Can you provide me the detailed steps you took to dye your leather? I also see that different people are using different methods of finishing such as resolene or wax? If there a preference or a big difference?
FeaungieCan you provide me the detailed steps you took to dye your leather? I also see that different people are using different methods of finishing such as resolene or wax? If there a preference or a big difference?
