1 - 15 of 15 Posts
i have a new black set of fuel and dummy caps, but I'm unable to remove the existing chrome dummy cap. It seems the outer shell just spins. Anyone have any advice on how to remove it??
I have tried the counter-clockwise turning, but again, it seems the chrome outer shell is the only thing spinning. Thank you for the thread....I was unable to find a thread.
No worries. sometimes the search don't work for me and I get nothing which sucks.
When trying to unscrew it may seam like it's not coming off since there are many threads on the stud. Try unscrewing and unscrewing, it should come off.
Had the same issue with mine. The thread lock or what ever it was (rust) was so tight that the top of the cap just spun on the bottom one (see picture). I had to take a soft cloth and place it on the tank underneath the dummy cap, I then placed some needle nose pliers under the cap to grab the screw and turn it until it broke loose from the rust. PITA. Getting bike painted so I really didn't care to scratch paint. I didn't. But that's just how I did it. So good luck and be careful if you decided you are going to try it.
In the pic you can see a black cap under the chrome cap. The chrome part will just spin on top of the black part if the screw is rusted stuck.
are you trying to be funny?? I would expect better from a gold member....
Nope, not trying to be funny hear. When I took mine off it unscrewed forever as their fine threads and quite a long stud for the application. I wasn't aware that some had thread lock or corrosion on them though sounds like if that's your case than Lumbee has the answer.
I don't know about you expecting better from a gold member... It just means that I donated money to keep the site going.
Nice. I went in on saturday and got a set added to the bike and the guy had it done in less than ten mins. I was like WTH. LOL
Gold member
Well thank you for your support and keeping this forum going! Hats off to you. Have a good day!
Sorry someone else may have already said this but the stock cap has a mile of threads. so it takes some twisting to get it off. I took mine off the first day I owned it. I was used to twin tanks and thought I was having issues getting the cap off the first fill up.
Thank you all for the help as well. I had the problem that the bolt was rusted into the threads on the tank. I put down a towel on the tank, then squirted some WD-40 on those threads. Next, I used a long screwdriver to gently pry up the the cap and then slid a pair of long-nosed vise grips underneath the cap to grip onto the black housing around the bolt. Once I got gripped and clicked, I gently turned counter-clockwise and heard the bolt break loose. From there it was simple. Make sure to protect the tank from the tools though. I had to learn to be patient, not rough, and try to out-wit the thing instead of out-muscle it. Thanks again for this help.
1 - 15 of 15 Posts
