I recently purchased the Driver Backrest for my Chieftain. I installed it and went for a ride only to find that it seemed to push me forward somewhat. Even adjusting the thumb-screw all the way to the back it still feels like I was pushed forward more than I wanted. SO..... I just spent a little time pulling the backrest apart and noticing that the main bar was bent at the top in a forward bend which pushes the backrest forward. I reversed the bar, removed the thumb-screw (Had to chase the threads with a die) and simply reversed the bar so the bend is now bending to the rear. Put it all back together and it seems like it did the trick. Only negative is the 'detents' in the bar don't seem to hold in holder. That's ok with me since I usually have the backrest in the down position anyway.
If you feel pushed forward with the Rider Backrest give this a try and see what you think.
