1 - 15 of 15 Posts
What is the difference between:
Thunder Stroke Stage 1 Performance Air Intake
Item # 2881779-521
and
Thunder Stroke High Flow Air Intake with Stage 1 Calibration
Item # 2880654-156
They are both the same price! But the first can only be dealer installed.
either of them can be installed by the rider to save labor cost. Just take the bike to them after to have them use the calibration card that comes with it to get the fueling right.
The difference between the 2 are 1. the looks 2. The high flow claims an increase in horsepower.
The performance Ram style air cleaner does not come with a washable filter, thus it needs to be replaced every 10K. The High Flow air filter will last a lifetime with proper care...
Reactions: theMucker
Item # 2881779-521
and
Item # 2880654-156
Item # 2881779-521
and
Item # 2880654-156
So far everyone I've talked to who does custom tunes prefers the round one over the oval "high performance"
The round one does not get as hot as the "high performance". The Oval one picks up more engine heat and doesn't breathe as free.
Anyway, that's what I was told.
But I like the oval one because the air filter is covered so you hear less noise. But at the same time I don’t like the filter because the shape causes the edge of the filter housing to touch my leg when I ride so I keep bouncing back and forth between the two not knowing which to get.
The round one has a washable element while the oval has a paper element you have to buy every time you change. Cheaper to wash the re-usable one.
weeeeelllll....not exactly....I wash, rinse, and dry my filter element about once a year with no issues...you just have to be careful and not scrub too hard. I usually use some Simple Green and a soft toothbrush.
Interesting. How long have you been washing it? Does it look like paper but really designed to be washed?
I installed it back in 2018, so at least twice since then. It is not paper in the sense of "it's going to fall apart if it gets wet", but paper as in "hey, this thing might get wet sometimes, so we need to make it thicker".
The round unit emits an audible intake noise, which I did not want. The oval air cleaner makes no sound that I can hear from the rider's seat. If either one really makes a noticeable improvement in performance over the OEM airbox, I can't feel it with my arse dynamometer. The OEM unit took lots of cool air from the openings at the front of the frame and might have been able to produce a positive pressure (RAM air) if it didn't have another opening at it's inboard, front area.
I DO like the looks of the oval unit though.
Personally, I like hearing that big round one suck the air when you about 3/4 throttle. You can literally hear it sucking the air in. Badass in my mind...
Reactions: Malboo
Did you put that design on the oval air intake?
Yes. It was easy. Just a piece of 1/16" thick black plastic painted to match the bike. The "Roadmaster" came off of the original lower fairings and I attached it with double sided tape.
Thanks.
With the black oval air cleaner I prefer the looks of the round one only because I don’t like the looks of the completely black oval cover without some chrome or color to break it up. Because of that I like the looks of the stock air cover because it at least breaks the completely mat black air cleaner with a silver center insert.
And the round black air cleaner has silver lettering.
Since my 2018 Chieftain Limited engine and exhaust are a combination of both black and chrome I’ve been trying to decide if I go with the oval air cleaner do I go black or chrome?
1 - 15 of 15 Posts
