It’s hard to overestimate the importance of tires for the trouble-free operation of your motorcycle. Your tires are the only thing that connects your machine with the ground, so sudden blowout or puncture may have severe consequences. That is why it is crucial to monitor the condition of your tires at all times. Underinflated tires run much hotter than normal resulting in their accelerated wear and making your bike handle poorly.
On the other hand, overinflated tires reduce tire contact with the road resulting in insufficient traction which can also lead to an accident on a bumpy road. And even if you check the pressure before the trip, you can always catch a nail on the road. These are the reasons why many motorcycle manufacturers include tire pressure monitoring systems into their premium model equipment. Today, you can easily add this safety feature to your bike by getting the TPMS kit by Torxe.
TORXE™ TPMS-02 - 2-Tire TPMS Kit – MOTORCYCLEiD.com
Specifications:
Frequency: 433.92MHz
Monitor display output voltage: DC5V
Monitor working temperature: -4ºF - 176ºF (-20ºC - 80ºC)
Monitor storage temperature: -22ºF - 185ºF (-30ºC - -85ºC)
Monitor dimensions: 2.28”L x 1.89”W x 0.90”H (58mmL x 48mmW x 23mmH)
Monitor weight: 1.83 oz. (52g)
Sensor transmission power: <10dBm
Sensor working temperature: -40ºF - 176ºF (-40ºC - 80ºC)
Sensor storage temperature: -40ºF - 185ºF (-40ºC - 85ºC)
Sensor pressure range: 0-87 psi (0-6 bar)
Sensor pressure accuracy: ± 1.5 psi (± 0.1 bar)
Sensor temperature accuracy: ± 6.3ºF (± 3ºC)
Sensor battery life: more than 2 years
Sensor dimensions: 0.82”D x 0.688”H (21mmD x 17.5mmH)
Sensor weight: 0.31 oz. (9g)
Features:
Monitor displays pressure or temperature for both tires simultaneously
Easily toggles between pressure and temperature displays
Pressure unit selectable (psi or bar)
Temperature unit selectable (Fahrenheit or Celsius)
Warnings for high pressure, low pressure, high temperature, fast leakage, and sensor low battery
Alerts warning with flashing display and audible alarm
Programmable with selectable parameters
The monitor contains a rechargeable battery
Monitor battery recharges via included USB charging cable
Monitor backlight illuminates automatically when ambient light is insufficient
Monitor battery saving mode – shuts down after 15 minutes when the bike is not in motion
2 valve stem mount sensors
Sensors contain CR1632 replaceable lithium batteries
Includes tool to disassemble sensors for battery replacement
Warranty: 1 year
To browse all available tire pressure monitoring systems, click on the button below:
If you have any questions, feel free to ask them here or call our tech experts at 888.903.4344
