Well I didn't think it was going to happen, but unfortunately it did. I got a Stebel air horn, and I thought it was tucked in well enough in the front of the frame near the stock horn location on a 2019 RM and woe is me. Its one of those 2 in 1 kind of units, the pump connects directly to the horn unit so there's not any hose to run to the horn. So I removed the horn and figured I could separate the pump from the horn. I was able to. But in the process of doing so, the portion of the pump that went in to the horn, broke off entirely.
Now I think I can get them mounted separately, but I need a new pump. This little pump puts out some good psi, which I imagine is like 13-15 or something like that (of course the manufacturer doesn't say). I have an old pump that came with my Rivcos I had on my Honda that I left on it, because I thought the Stebel would work on the Indian. It still might. On the left or right side of the frame I can zip tie it or hose clamp the pump to the down tube there out of the way of anything moving. And I think there is still enough room to mount the plastic horn portion back where I had the whole unit to begin with. I'll have to order a new pump, and then some how get it rigged up. I went to get my superglue to try and get something to work as I had a piece of .30-30 brass I cut in half, and stuck the neck in the hole on the horn with some rubber hose over it. Well my unopened tube of superglue, was super dead and hard in the tube. So I couldn't just get something put together for a couple days to at least have a horn to use. I guess I lost the stock horn I can't find it to just throw it on for now.
Or my other option I was looking at was one of the two I used on my Honda before. I parallel relay wired two air horn units on it and let them both go with it when I traded it, one the Rivco and the other an Amazon special that was pretty decent. I was looking at the similar 18 inch trumpet. I was thinking maybe I might be able to run it down the tube on the right side of the frame and point the bell to the ground by the leg fairing. Mount the pump on the other side of the frame and a short hose to the horn. I guess the only way to know is to order it and see. Because I need the pump anyways if the trumpet is too big or whatever. Then I can get some parts to fit in and glue or something in to the horn to get a hose on.
I know there are the Buffalo Brand horns and others that mount on the right side of the stock location of the horn at the motor just below the tank. I don't even know what is over there under that cover on my 2019 RM, as I don't think it's the horn since it was mounted in front. In addition, I'd be interested to hear from those that have used that stock location to mount air horns on older model Indians, if the horn hits the leg at all. Since I'm short, I don't know if I leg would hit it. If you made it this far, thanks! Long winded but trying to weigh as many options or ideas from others' experiences.
Heres a pic of the horn tucked in behind the cooler and motor against the frame near the stock location of the little stock meep meep horn. I don't know if the dent can be seen, I couldn't get a good look at it on my phone cam. Maybe it's just the light reflecting off the fender. But there is a big ole dent in it now. And the other pic of the broken piece on the pump when I separated the plastic from it. The plastic was glued on 3 areas. Both sides of the horn the black plastic wraps around, and then in line with the air output port if anyone else was thinking to try it. Probably better not.
