Went out to the garage tonight, feeling giddy as I took my bike cover off, and smiling in anticipation of the ride I was about to enjoy. Pushed the starter switch..and nothing. Huh? Tried a couple more times, then checked the voltage reading on the display and 9 volts is all that was showing. I have 1500 miles on my bike, purchased less than 2 months ago, so quite the surprise. It has only been 10-12 days since I last rode, so very surprised a battery cannot make it that long without dropping that much voltage. Pulled the battery out and slow charging, so will see what happens. I previously rode a 2016 Dark Horse before buying this Challenger and always had my battery tender plugged in when not riding. For some reason, I have not used the tender on the new bike, but apparently I need to go back to my old maintenance habits. YUASA is a good battery, so don't think I can blame them. Just thought I would share, as I have seen a few posts about Challenger batteries going dead!
UPDATE: The battery charged completely, and after 24 hours off the tender, the resting voltage was holding above 12.7v. Reinstalled and checked voltage again after 12 hours in the bike and it was holding at 12.4v (gauge display reads 12.2). Bike ran no problem and after checking voltage again the next morning, battery was reading at 12.4v again. The gauge display seems to normally read 12.2 when initially activating the electronics. Bottom line, batter tender is connected and will be a normal part of my preventive maintenance again.
