1 - 6 of 6 Posts
2019 Roadmaster
Heat gun or hair dryer, heat up the adhesive and peel them off. Then use rubbing alcohol to remove left over residue
Sent from my SM-G988U using Tapatalk
2012 Challenger Limited, Ruby Red Metallic
The heat gun works great, but I've always used GooGone instead of the alcohol afterwords. Works better, IMO.
Also, after the heat gun, get some monofilament fishing line to run between the chrome piece and the adhesive. The Chrome piece will come off and then you'll peel off the remaining sticky tape. Use the googone to clean up the residue.
Reactions: mnoutdoors
Has anybody installed these lights? The instructions say to remove the existing chrome strip. How do you go about removing the original chrome strip?
Fender:
Did you get it? If not, easiest way is some plastic fishing line, saw the adhesive off.
1 - 6 of 6 Posts
