2015 Vintage is the bike.
The cruise control (CC) shuts off when I pull in the clutch handle in gears 4 & 5, as it should. But when I'm in 6th gear and CC is being used, cruise does NOT shut down when I pull in the clutch handle, and the engine revs. This only happens in 6th gear (I haven't checked gears 1 thru 3). It seems to me this would be a gear sensor issue, as opposed to a CC problem. Am I on track here or....? I haven't had the gear sensor cleaned or changed. Up until a few days ago it always worked as it should. What do you guys think? fwiw, the gear sensor icon on the speedo has always been a bit slow, but has been working ok.
Thoughts and or suggested cures are appreciated. Thanks
