1 - 8 of 8 Posts
I did a search before posting, no results, maybe I use wrong key words?
Does anyone make a Crank Case Breather relocation kit for the TS111? Don't like it venting/breathing into the air cleaner. I'm sure this has been discussed before....somewhere
German rider
No kit yet, but some Breather Filter available on f.e. amazon.
I only routed down a water hose near the oil filter w/o Breather Filter (some dudes route the hose in the upper frame above the air box), plugged the hole in the air box.
Now 1,000 mls since then the lower hose end is dry and clean, no catchthingy or Breather needed.
And... air filter stays dry.
As Zoidberg states, several ways to do it. I use to run mine down along the down tube of the frame:
Then with the Voodoo filter I wanted to clean it up a little so I cut the hose to 12", kept the filter on and ran it up into the frame where the rubber plug had been. This provides a path for any oil to flow back into the engine.
Part List:
Crankcase Filter Used
Hose Used
Discussion Starter #4
Part List:
Hose Used
Thank you Craig! Actually this helps me in 2 ways because I'm going to be going with the OTB VooDoo Intake, that's what prompted my question.
How do you like the VooDoo Intake system?
I like it a lot. Great performance and looks.
I ran the hose/filter up into the frame to try and get the oil vapor smell to go away but now it is worse. Is there a place to run the hose where the fumes will be pulled away from the rider and passenger?
You can run it along the down-tube of the frame.
Discussion Starter #8 (Edited)
Thank you for all your ideas and input Craig, this is what the tech in Sturgis did, short breather tube, the filter sits on the intake manifold, a fairly cool part of the engine. Its just above the top edge of the VooDoo Intake, easy to get to and maintain. No signs of oil in/on the filter so far.
1 - 8 of 8 Posts
