21 - 38 of 38 Posts
I'm having trouble finding red lens for the rear OEM turn signals on the Scout. Can use the run turn stop module if I can find the lens. Can anyone help?
What did you ask for? Does the OEM type plug you used have a number or name? Also the ends for the wires?
I just took pictures of the ends that I needed and asked Namz if they had it - the connection into each turn signal and then into the LED brake cluster.
If you're ordering the module from them, ask to speak to Tyler and mention my name. He should remember me and be able to pull up my order, which has the connectors you need. Keep in mind that the connectors have two parts - the shell and the internal metal pins, but its easily put together.
Has anyone added the brake light/ turn signal module from namz and the admore light. Will they work together?
Can you put the namz module on the rear fender light assembly? Looking to conserve space under the seat.
I know I will have to run pos and neg back from the battery.
Sent from my SM-N950U using Tapatalk
Bonjour, j'habite en France et j'ai un problème pour installer le module badlands.
J'ai lu toutes les étapes, mais je ne comprends pas tout.
POssicle pour vous me poncez une photo de votre installation? Sous un siège et un garde-boue merci beaucoup.
Bonjour, j'habite en France et j'ai un problème pour installer le module badlands. J'ai lu toutes les étapes, mais je ne comprends pas tout.
"Hello, I live in France and I have a problem installing the badlands module. I have read all the steps, but I do not understand everything. POssicle for you sand me a photo of your installation? Under a seat and a mudguard thank you very much."
Google translation. Not sure which badlands module you are trying to install. Are you putting this on a Roadmaster? What year and model motorcycle is it? After a quick Google search, it seems Badlands makes quite a few products for the rear lights. Maybe you can give us some more information, and some pictures of what you are trying to do. Or a product number or link to the item you are trying to install. And hopefully we can help!
21 - 38 of 38 Posts
