1 - 4 of 4 Posts
I am weighing the options of doing aftermarket 6.5's all the way around. The only thing I am not sure of is what connections the back of the head unit has. I was just wondering if anyone has info or pictures of how standard speaker wires would plug into the back of the head unit. Thanks.
Disclaimer: I am fully aware of the plug and play powerband audio option, just exploring all of my options.
2020 Indian Challenger
From what I've seen this isn't a typical head unit. It might be easier to connect to the factory speaker connection. I don't use Facebook but there was a guy on there that did a lot of cool things with his. He put a couple of 8's and a 10 if I remember right. There's a separate amp for the saddlebag speakers. You might be able to tap into that connector. It's most likely an MX150 connector.
Edit: I just went and looked at the service manual and you can get to the pre-amp signals. My guess would be that you could get them from the amp connector. From there you would just need a different amp.
Link?
To what specificly? I happened to see it in passing on Facebook and I don't have an account. For the service manual, I have a physical copy.
1 - 4 of 4 Posts
