Took the bike for a ride a while back and by the end of the ride I noticed the clutch cable had loosened up. I had just got it back from the dealer from the break-in maintenance and figured maybe they had not completely tightened down the adjustment nut on the clutch cable.
Anyways, I adjusted the clutch cable back to how the manual says. Since then I've noticed that the clutch's friction zone has moved further away from the grip than it used to be. It isn't causing any issues, I just wanted to ask any of you if you know how to adjust the friction zone closer or further away from the grip.
Also, if any of you know of an after market dip stick, I've been trying to hunt one of those down too.
