(I just posted this in the FB group)
Anyone having clutch hiccups with their Challenger?
I’ve seen several posts about bad cables, cable adjustment needing to be very exact (0.5-1.5mm freeplay,) clutch slipping & one guy reporting a “popped clutch plate” although I cannot find his post.
LISTEN UP INDIAN if you monitor this forum.
My issue:
...about 50% of time when slowing to an intersection & dropping from 2nd to N,, and then when stopped to 1st, -it clunks (sounds like it went into 1st) but stays in N.
Clutch out confirms N.
Clutch in, tap down... clunk,, display shows 1, then a sec later changes to N. 3rd try seems to stick; but occasionally I have to HOLD shifter down in 1st to get going & then all is normal. Kinda frustrating.
Others & I have installed the $57 Barnett cable (very smooth, sleeve is 1mm thicker than oem, but actual cable is same 2.3mm thickness. We know the Barnett cable is USA steel; the Indian cable?) Our cable freeplay is correct per manual.
One rider reported his issue & dealer told him it WASN’T warranty covered cuz the clutch is a “wear or maintenance” item. I bet we all will yell BULLSHIT to that right?
INDIAN/POLARIS, care to speak-up?
INDIAN... do you offer a heavy-duty clutch kit for this bike? ...you better get one ready, and respond proactively towards us please.
Barnett is making one (see image of my email comm with them) -however we should NOT need to go aftermarket for another clutch able to handle this new bike/engine.
IF more riders experience clutch issues as the miles rack up & open service cases, AND Indian doesn’t have a stronger clutch, I HOPE that Indian will do the right thing and put a Barnett clutch kit in the bike under warranty or reimburse us for it.
My issue:
