1 - 6 of 6 Posts
did you accidently dump the clutch and made it stall?.. try cycling through the start up cycle a few times and take her out for a ride..
Thank you. Yeah I did dump the clutch :(. That's what I was hoping was the cause. I checked the oil to make sure that wasn't it
It will clear up. I did something similar. Kicked from 2nd to 3rd instead on neutral then lowered the kick stand. Check engine light stayed on for 2 days. Then went off on my way to the dealer.
1 - 6 of 6 Posts
