1 - 6 of 6 Posts
2016 Vintage with 116/stock tune. As I toggle thru the display a check engine indication comes up. Interestingly, when checking for fault codes with my PVCX no codes appear. I go ahead and have the PVCX clear codes anyway but the check engine display remains with no codes evident.
Any ideas?
How many times have you started/stopped the bike since it appeared? The light normally takes 5 cycles to disappear. If it's a transitory code, such as a misfire on starting, and then the bike runs OK the code seems to fall off the list before that.
Sometimes I get a misfire and I think it's because the decompression mechanism takes a full turn to operate and the motor gives a little kickback on the first revolution, depending on how close to TDC a piston stops.
Iam at the dealer this morning for the gear position recall. Let them figure it out. Your probably right, thanks.
Good to see that they found it.
My 'learn a new thing each day' from last week was finding out that a blown headlight will make the high beam indicator flash. Was that happening?
No indication other than a chk eng message that kept showing up on the Vintage’s display when scrolling thru the menu (mileage, temp, fuel,voltage,etc.). All fix now, happy Indian.
1 - 6 of 6 Posts
