I was headed to work yesterday, and I stopped at a gas station to fill up then back on the road I go. No more than 200 ft away from the gas station, my bike dies doing about 45 mph.
Originally I thought I hit the kill switch on accident, but that wasn't the case. I try starting it as I was still cruising, no luck. It tries to turn over and nothing comes out of it. I pulled off to the side to call a friend with jumper cables to attempt and start it that way, still the same issue. I got it towed to my work, during my lunch break I have another friend hook up the jumper cables to it and let it sit for a bit, still nothing. I get a new battery to install and check all the fuses, no visible damage to the fuses but it still won't turn on. Got an extra spark plug to see if it's sparking and it is as it's supposed to. So today I will be taking out the spark plugs to see if they're fouled and test if they're getting fuel.
Has anyone had a similar experience or can shed some light on what could be the cause or what else I can try?
